Notices
'06 silverado 1500 torque converter trouble! need advice!
Old April 16th, 2013, 1:29 PM
flyboy94's Avatar
Default '06 silverado 1500 torque converter trouble! need advice!
Hey everybody!
I'm new to the forum, so sorry if I'm posting in the wrong spot... Anyway I'm going to explain my problem and maybe somebody will know whats going on. When I'm driving my truck (v6 automatic 1500) at highway speeds between 45 and 65+, when the torque converter kicks in, it keeps turning on and off, it makes the engine sound like it's revving a few hundred rpms and then dropping back down. It keep doing this as long as I'm traveling between those speeds. I talked to a transmission shop over the phone and he said I needed a full torque converter/transmission rebuild which he quote $1500.00 to do... I'm just wondering if someone else has had this problem and maybe there's another solution? Also the guy that had it before me added a cold air intake (k&n) and a straight pipe dual exhaust so it sounds really good but also makes the engine fluctuation noise louder. Maybe the addition of the new intake and pipes has thrown something off? If anybody has any ideas I would greatly appreciate it! I'm 18 and as I don't have a lot of money I'm trying to make sure there isn't another option before I do a rebuild. Thanks a million!
Cody
Old April 16th, 2013, 1:31 PM
kevinkpk's Avatar
Scratching my head, V6 manual?
Old April 16th, 2013, 1:45 PM
flyboy94's Avatar
oops! I meant automatic sorry
Old April 16th, 2013, 1:47 PM
kevinkpk's Avatar
Does this have the tow/haul switch? Is it a six speed?
Old April 16th, 2013, 1:50 PM
flyboy94's Avatar
yes it does have the tow/haul switch, and it is a six speed I believe.
Old April 16th, 2013, 1:57 PM
kevinkpk's Avatar
The torque converter dosen't "kick in" it is a centrigual pump. I suspect either you have tow/haul switch in, or a shift solenoid issue. How many miles, and what kind of life?
Old April 16th, 2013, 2:01 PM
flyboy94's Avatar
ok thanks for the clarification, I wasn't sure on that I just assumed that's what it did. What do you mean by a tow/haul switch "in"? it has 174K on it and virtually all highway miles as far as I know.
Old April 16th, 2013, 2:17 PM
flyboy94's Avatar
thanks for your quick replies btw!
Old April 16th, 2013, 2:37 PM
kevinkpk's Avatar
Look at the gear shift end, it will say tow/haul, also the switch will be a pushbutton on the end of the gear shift. Not familiar with a 6 other than a manual tranny. I don't suspect it is major, but it shouldn't be shifting. What tow/haul does is keep the tranny from shifting at different shift speeds, in other words it changes the tranny shift points when you select it if you are towing something.
Old April 16th, 2013, 2:40 PM
flyboy94's Avatar
ok I will check that out thanks a lot!!
Quick Reply: '06 silverado 1500 torque converter trouble! need advice!
