1985 K10 with fast idle and violent shut off
Hey guys I have a 1985 K10 with a 350 crate engine, new distributer, and edelbrock intake and carb. It has a good idle in drive and reverse but when I shift to park our neutral, the idle gets really fast. Then when I shut it off the truck shakes and does weird stuff. Here's a link:
Do anyone know what's wrong/how to fix this? Thanks -Ryan |
What octane gas? What is the idle timming advance set to?
87 octane I think for regular at Shell. I'm not sure what the timing is, the truck ran fine before but it just recently started doing this
I would set the timming at 10-12 btdc at 750 rpm. Dieseling is usually either gas, or too far advanced timming. Is it slow to crank when starting?
no its not slow, how would i set that that timing?
Originally Posted by Ryguy316
(Post 228157)
ok cool, and the carb is a 600cfm. would changing the timing fix a clicking that i hear from the distributer also?
(Post 228160)
Originally Posted by kevinkpk
(Post 228163)
Thats an hei, clicking could be part of your problem. Can you do another you tube on it? Clicking in a point distributor could be spring or advance base plate, however that shouldn't case dieseling on shut off, that again is fuel, or timming. 600 cfm is fine for a street runner on a 350, however what cam is in it? If you have a long duration cam that could also point to higher octane to keep it from desieling, but with a standard build 87 (good gas) should be ok. My 455 likes higher octane but standard 455 it uses 87 also.
(Post 228449)
Ok so i got a timing gun and the timing was too far advanced. I set the timing to 12 btdc, however this didn't fix the problem. My truck still idles unbearably fast and still "diesels" when i shut it off. However, when it is idling high, i can STOMP on the engine for a split second and when it goes back to idle, its a nice average idle. So could this have to do with the carburetor and the (wow the word for it is fleeting me) "gas wire" that connects the pedal to the carb?
