1989 chevy 2500 crewcab dually "transmission fixed"!
Just wanted to leave a little info on what i did to fix my transmission shifting problem.the truck would wind out before shifting into 2nd then go into 3rd and go in and out of gears while driving on frwy. I went underneath and checked all electronic connectors on trans ,they were all ok.then found a rubber vacuum line on pass.side of trans that was loose.changed it out with a new one and presto!!! Transmission shifts perfectly ever after!! Hopefully this may help someone else out . Chuck.
Yes Sir,
That would sure do it. Without vacuum on those 400s, the governor pressure/modulator valve can't overcome the built in spring pressure of the modulator.
Don't see that much anymore since they've gotten away from using a modulator on the newer transmissions.
Good catch!
Allan
Good catch!
Allan
bamafutbal
November 3rd, 2012 7:59 AM
gonegonzzo
December 18th, 2010 10:13 PM
glamisfanatic
Silverado & Fullsize Pick-ups
August 12th, 2010 11:48 AM
suburban3
June 16th, 2010 12:07 AM
1989, 2500, 89, cab, chevy, crew, dually, modular, problems, tiene, tranmisioan, transmission, transmissions, truck, una
