1995 chevy 1500 truck wont shut off
Ok i recently pur a used motor in my truck but when i hooked the battery back up everything turned on like the key was turned on but the switch was off and when i started it i could out shut it off so i just put in a battery cut off switch but now my truck wont start i can get too start by mashing the gas but i have to keep hitting the gas till it smooth out but it acts like it skipping but i just put new spark plugs and rotor but it did help
Same issue
I'm having the same issue after pulling my 5.7L to replace some seals. When I hooked up the battery, lights came on in the dash. Started ran good, then turned the key off and kept running. Mine is a stick I just stalled it out and disconnected the battery. Where did you find the wiring problem at? I would appreciate and guidance.
Ok, I was able to fix my no shut off issue. I found the fuse box on the driver side fender, opened it up. Pulled fuses and fount 2 that stopped the power from getting to the coil. 20A Eng and 20A horn. I disconnected the battery pulled the 2 fuses. Reconnected the battery while fuses were out and I heard a click, like a relay in the fuse box resetting. I reinstalled the fuses and problem was fixed.
luvche
Cobalt
May 31st, 2014 1:44 AM
Newto4x4
May 9th, 2013 1:34 PM
