2000 Chevy 1500 2WD Issues
*"I have a 2000 chevy 1500 2wd when you start the truck it will start then aost immediately die this morning when it did this then all the lights would go out after I let it set for about 5 minutes you could turn the key and the lights come on and the clock resets
Just got a call from the wife starts now and acts normal WTF? Can anyone help I am at my wits end with this thing I have dropped 1500 dollars in it since january doing a tune up and replacing the fuel pump
Please can someone help me
Man that sounds like something to do with your battery or charging system if the clock resets. I would check the cables and connections to make sure everything is good.
I would check your cables and also have your alternator checked. Oriellys will check the alternator for free. It sounds like a loose connection, but could be also caused by the alternator not charging your battery like it should. Just a thought.
Definately check for oxidized battery cable connections !!!!!
