2000 gmc 6 lug to 5 lug
Does anyone know if you can swap out rear ends or axles from a five lug chevy and spindles onto a 2000 gmc to make it 5 lug i am interested in a certain rim and they only make them in 5 lug i dont want to use addapters.Would like to know if anyone has done this any advice would be apreciated.This is a 2wd truck.
why do you want to do this? There are many rims in 6 lug that look great. You would also have to carry 2 spares, one 5 lug and one 6 lug!
6 lug to 5 lug
I cant find the rims i want in 6 lug and why would i have to carry 2 spares if i converted it over?
Even with junkyard parts, the price of the parts + new upper and lower ball joints + new axle seals + new cover gasket and diff fluid + the price of the rims you want = enough money to have a custom set made for your 6 lug. There has got to be at least 100 different wheels out there for 6 lug trucks and you can only find 1 that you like?
You only talked about changing the rear axle and did not mention the front. I was wrong but I thought you were only doing the rear.
Originally Posted by dirttracker00
(Post 226911)
I would keep looking and find a 6 lug wheel that I like that fits. |
Swap axles
I've got a 4WD 2001 Silverado 5-lug entire rear axle that I'll swap for your 6-lug. We can check rear end ratios, drive shaft angles ,etc. if you want to swap.
Sorry. I screwed up. My rear axle's a 6-lug. I was looking to get a HD rear axle on my K1500.
