2000 Silverado CD player
http://im1.shutterfly.com/media/47a2...3D550/ry%3D400My 2000 silverado has a radio/cassette player with a separate CD player, (lower part of the picture) when I put a CD in it it shows CD on the read out on the radio but then shows ERR and ejects the CD. I tried different CD's and the car was still when I tried it so I know it wasn't movement or bumps causing that, do any of you have an idea where I can start looking to fix this? Thanks in advance for any suggestions
The cd heads might be dirty? This is something I am not well up on, but check with an electronics or auto parts store to see if there is something to clean it with.
I will check that out, thank you
If it was me, I'd just replace the stereo with an aftermarket unit.
they make a CD cleaner. It is a CD with little brushes on it. It also comes with a cleaning solution. Put cleaner on brushes and put it in the player. Follow directions or let it play. It doesn't always work, but it is worth a try.
