Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2014-Present: Why is My Truck Idling Rough?
Guide to diagnose trouble and recommended solutions
2001 Chevy Silverado engine idiling rough
#11
Not sure what you mean by tune, but a newer vehicle will drive/run differently after the battery is disconnected and the ECM is reset, it will take a few drive cycles to relearn certain things.
#12
I had my truck professionally tuned by a friend at Carolina Speed Shop; so if the computer completely loses power it reverts back to its original state? If so, would that mean that the things he changed would be lost?
#13
Thanks for the reply. I will disconnect the battery when I get home and see how that does. It does have a MAS sensor, it is right after the air filter box. I wish I would have found this forum before I tried the other suggestion. I hooked it back up after I sprayed cleaner into the intake.
As far as the spark plugs, I used autolite 5245s which is also a suitible sub for the AC Delco.
I will try the battery and if that doesn't work I will go to the spark plugs and change them out. ingers crossed it will fix the problem.
I forgot in my first post that the engine is 5.3l vortec.
Jared Phillips
Silverado & Fullsize Pick-ups
25
July 22nd, 2021 6:55 PM
crappydonkey
November 2nd, 2013 9:16 PM
Joshua Wayne Tweedell
February 18th, 2012 9:36 AM
