2007 2500 classic makes knock when turning left
Hello all and thanks for any help.
I have a 2007 2500 classic that makes a knock then slightly turning to the left. It will do this when going 5 mph or 60 mph. Same sound regardless of speed. It will not do it when stopped which is making it hard to figure out. It sounds like it is coming from the front right side of the pickup. All tie rods feel tight. Does not make any sound when turning to the right.
Could it be a CV issue beings the pickup has to be moving?
Thank you,
Thank you,
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> arnz9839,
It may be a CV issue. Do you have any aftermarket equipment installed on the vehicle (i.e. step assist bars)?
Louis
GM Customer Service
Louis
GM Customer Service
Louis,
I do have a 3" Skyjacker lift installed. I don't know why I didn't write that down when I initially described my pickup. It is getting worse however I just my pickup for work (I farm) and it has been a hectic week to where I did not have time to get it in the shop. This week I will look into it.
Thank you for your replies.
Official GM Rep
Understandable. Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
T-bone
Silverado & Fullsize Pick-ups
March 6th, 2012 3:33 PM
JasonT
October 6th, 2009 10:56 AM
julio
October 17th, 2007 6:05 PM
