383 stroker help! 2000 silverado
hello, i have a 2000 chevy silverado ext cab z71 with a 5.3 vortec. my dad is a machinest and highly qualified mechanic. we want to swap my 5.3 for a 5.7 and stroke it to a 383 stroker. what i want to know is what complications will we cross? i relize the intake wont fit but what else will i need to change or swap such as computer, tbi, exhaust, motor mounts, intake manifold, exhaust manifolds, all the componants like ac, alternator, power steering pump etc .or would u have the specs or a recomendation to build up the 5.3 or a stroker kit for it? any information is highly apreciated thanks
RE: 383 stroker help! 2000 silverado
Unless things have changed in the last few years all the externals should be a direct bolt on. If you can get a complete 5.7 form air cleaner to cats, and computer that would make it easier though. Your engine mounts and radiator and hoses should work fine. If you do find a 5.7 and decide to put that in Summit racing has a 383 stroker kit for the vortec engines. It cost around 1000 dollars.
Their # is 1-800-230-3030
Good luck
Good luck
You won't have to re wire anything!
All external parts bolt up
But a 383 is kind of a waste because of all the extra parts
I would look into a 6.0L block and stroke it to a 402ci
Then use L92 heads and L76 intake and bam
Good to go
Or look into a 370ci
Good to go
New User
Awaiting E-mail Confirmation
"Speaking from experience"
If I were you I would spend the extra money and and get a reinforced race block and start from there and build it up
adairfuentes
Silverado & Fullsize Pick-ups
October 18th, 2014 4:04 PM
chevykicksbut
October 13th, 2010 4:12 PM
