4l60e id
how do you tell a 93-94 c1500 4l60e from the rest.
thanx |
anybody know?????
there should be an tag on the case which identifies the date of assembly. I will have to get back to you to tell you what it is exactly.
Ok thanx
Before 93s dont have electronic valve body so they have mechanical TV cable linkage. 93 & 94s dont have a lock up converter solenoid. but 94-to 96 have a plug in the case for the lock-up. Plus 95-up have auxilliary valve bodies and 96-ups dont have screw in SAE fittings in the case, they use NPT.
ok. i don't see any tags on mine.all i can see is m30 on the case.
i was having trouble with the shift from 1 to 2 and was getting a code 67 so i changed the shift solenoids and the lockup solenoid. didn't help anything but it did knock the code i was getting out. since i have a lockout solenoid i guess that makes mine a 94-96 or am i wrong . i'm trying to find a replacement but need to know whether i'm getting one that will work with my truck. i found one and the tag says 3ckd on it and everything else looks the same. thanx for the replies |
