95' Z71 ABS light on and will not flash code
95' Z71 ABS light on and will not flash code, I looked up a site that rebuilds the hydraulic units and it says, remove the abs fuse or repair as soon as possible the hydraulic unit motor will keep running causing the battery to run down and the motor will burn out over time. I think the motor is already toast previous owner said abs and battery running down for years. now I've learned they only repair 99 and newer so the parts about $450 or more and I have to have 3 special tools to bleed the EBCM unit/ electronic brake control. Does anybody have any help for me on this
Dose the vehicle jostle under breaking?
Have you done any brake repair lately? |
