Notices
Sponsored by: DashLynx
99 Chevy Silverado turns over but won't start
Old October 12th, 2012, 1:18 PM
New User
Awaiting E-mail Confirmation
Ddefee81's Avatar
Default 99 Chevy Silverado turns over but won't start
I have a 99 Chevy Silverado 1500 with a 4.3, about a month ago the clutchwent through the fire wall, fixed it. we was pulling the truck to a safer location other than the side of the road, it died as soon as it was tugged on. it wasn't a yank it was a very light tug. Now it turns over but won't crank, it is driving us crazy. Can someone please help!!!!!
Old October 12th, 2012, 2:47 PM
kevinkpk's Avatar
You should have a check engine light, with that you should have someone with a code reader get the code.
Old October 13th, 2012, 9:18 AM
Make sure any wires didn't get disconnected. Also check your fuel pressure to make sure sure you are getting the correct pressure. Check the codes that will lead you in the right direction.
Old October 15th, 2012, 9:30 PM
Chad Cratsenburg's Avatar
I had a similar problem with my 01 silverado. Is there a security light on your dash blinking when you turn the ignition on? If so double check all of your fuses. mine was cause by a chassis control module fuse that was out. Also if that does not work you can try a 30min re-learn. just look up the re-lean process for your truck.
ChevyMan333
13
May 4th, 2021 5:07 AM
runningon61
May 4th, 2021 4:24 AM
djchevtech
June 9th, 2014 9:28 PM
thisnthat
November 20th, 2012 11:36 AM
Kurtleathers
June 2nd, 2009 6:55 PM
Quick Reply: 99 Chevy Silverado turns over but won't start
