Aftermarket Radio Install - Issues 2006 Silverado
I purchased a 2006 silverado with the work truck package last week and tried to install a aftermarket radio in it tonight. I have absolutely hit a wall trying to get this installed as there some issue with the harness that does not allow for switched wiring from the factory deck. So I tried to attach a fuse tap into the 10a SEO Accesory however I have cd power (hear noise as it is conncected) but no lights. What have I done? Do I need higher amperage?
Wait you cant disconect the harnes to put the after market harnes in?
I purchased a Sony deck and it came with a harness in the box. I cut the old harness off of the factory deck and just started connecting wires to each other with wire nuts. All wires matched except the truck does not have a switched power wire.
I figured it out. My mistake was that I had wired the antenna wire to the data line (small orange). Everything is working now. Thanks for the help.
