Notices
Old July 27th, 2015, 3:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
belt squeak, but not the belt? help please
Old April 29th, 2012, 9:47 AM
  #11
96 Junk That Moves's Avatar
If you take the belt off and there is no noise there could be rubber build up on the pullys from the old belt. Put some valve lapping compound on the belt and run the truck for a day. the buildup lets the belt slip thus the noise.
Old April 29th, 2012, 1:34 PM
  #12
You probably won't spin it fast enough to hear. It also won't have any load on it. When you spin them check to see if the feel good or rough. If it feels rough then the bearing is going bad.
Old March 30th, 2014, 8:16 AM
  #13
joshbranson's Avatar
Originally Posted by landon101
hey all i have a 1997 chevy 1500 4x4 5.7 and ive been hearing a loud squeel while idling and driving so i changed the serpentine belt and also the auto adjustment.."pulley"?( not sure exactly what its called) but the one you can leverage down to take off the belt. Is there something im missing what else could the noise still be coming from?
I have a 1997k 1500 I fixed mine after 2 new belts and a altanator. You have to flip the belt inside out
Fawnevins (November 14th, 2021)
Old March 30th, 2014, 8:18 AM
  #14
Best way to stop the squeak is to turn the belt inside out. It cost me around $150 to figurer out but it works after 2 years of listen to the squeak
Old March 30th, 2014, 9:35 AM
  #15
Richardx2's Avatar
Ivory bar Soap helps reduce belt squeal also.
Old November 20th, 2016, 9:54 PM
  #16
Kevin Floyd's Avatar
Originally Posted by MDTAHOE
Take the belt back off and start the truck, is the noise still there?
So I'm having the same problem as this guy I took my belt off and still the noise is there
Old November 20th, 2016, 10:28 PM
  #17
So I'm having the same problem as this guy I took my belt off and still the noise is there need help please
Kelvin803 (January 17th, 2021)
Old August 15th, 2018, 10:33 AM
  #18
Yvonne Reeves's Avatar
I had all belts pulleys and tensioner changed in my 2008 Silverado.. still squeaking. I'm having the water pump and bearings changed as we speak. I hope that's what it is..I'm beyond frustrated. How hard is it to find the source of a squeak. 😢 I hope this fixes it. I've already put in about $700 into my truck in the past 2 weeks. Expensive damn squeak!
Old January 1st, 2020, 7:31 PM
  #19
CraigPiper's Avatar
Default Same issue as everyone else.. can’t figure out the damn squeal.
98 GMC 1500 5.7L. I just installed brand new alternator, beings that I’ve been having issues with no power. Also installed new water pump recently (fixed overheating issue). I went with a salvaged alternator first off but didn’t fix any power problems, and also seemed to be squealing a bit. So in goes new alternator but squealing got worse after that, still no juice from alternator. Tensioner pulley was wobbly so just replaced today. Still same squeal. Havnt tried starting with the belt off. If the squeal is still there then what would that entail if anyone would know? And also why am I not getting charge in alternator? I’ve checked the wires and terminal but seem to be fine. Also has new battery
The following 2 users liked this post by CraigPiper:
Bheine65 (March 3rd, 2020), Matt_clinard (January 30th, 2023)
Old January 17th, 2021, 2:19 PM
  #20
New User
Awaiting E-mail Confirmation
Kelvin803's Avatar
Default Noise
I’m having the same problem with belts off. Could it be timing chain? Did you find out the problem
Quick Reply: belt squeak, but not the belt? help please
