Notices
Sponsored by: DashLynx
Brakes not releasing
Old August 9th, 2010, 9:42 PM
coppola7's Avatar
Default Brakes not releasing
I have a 2003 Silverado 1500. The front brakes wont release once they are applied. Seems to only happen when the truck is running. Once the engine is turned off there is a slight release of the brakes but they are still on. All of the calipers seem to be OK, I was able to decompress them with a clamp using little force. Is there a release valve somewhere in the system that needs to be replaced? Could it be something in the ABS system? Can you help before I start changing parts unnecessarily?
Old August 9th, 2010, 11:12 PM
s34n's Avatar
how many miles are on it? it could be time for a rebuild kit or new calipers. what could be happening is the caliper is bad and obviously not releasing or the pins arent greased and getting stuck when applied.
Old August 10th, 2010, 7:10 AM
coppola7's Avatar
Default Silverado brakes
thanks for the reply. There are about 98000 miles on it. Original calipers. Pins are well greased and not binding. I could try rebuilding the calipers as they are probably due, but I was able to decompress them with a clamp.
Old August 10th, 2010, 7:12 AM
coppola7's Avatar
I still get the sense that it is something at the master cylender level that is not releasing even though the pedal releases, and is actually "higher" when this is happening.
Old August 10th, 2010, 9:01 AM
jrsavoie's Avatar
What are the best quality of calipers, rotors and flex hoses to buy?
I have currently been using Napa premium stuff.
Old August 10th, 2010, 6:51 PM
usmarine0905's Avatar
My 98 silverado did the same, and it was the brake hoses. I replaced both hoses and it fixed it. you could take them loose and see if the fluid flows freely. I replaced both calipers on mine and it still did the same, untill i replaced the hoses. I found out on mine by taking the hoses loose, and blowing into them... Old skool way....
Old August 10th, 2010, 8:14 PM
gotstylez's Avatar
what happens is on mos of the brake lines the metal inside the lines break..and its like a valve..once u push the peddle it stays instead of letting it release..i'd say replace the line .I've had a few that has done this to me.
Old August 10th, 2010, 8:41 PM
s34n's Avatar
is it hard to steer at all?
Old August 10th, 2010, 9:42 PM
Professional Mechanic
MDTAHOE's Avatar
I would replace the brake hose first, they are the most likely cause. Calipers would be second.
Old August 10th, 2010, 9:56 PM
gotstylez's Avatar
yeah..x2 on this
and to be clear on what i posted a second ago i was talking about the lines from the frame rail to the caliber..
Quick Reply: Brakes not releasing
