breaking header bolts on driver side
#11
You were more fortunate? than I was. My problem did not surface until after the warrenty period, so I had to deal with it myself ($). At some point you may have to do the same because my understanding is this is not a "one" time event. I've been told this is an on going problem with this model(6.0) and the fact that it took only 2 months to break a second bolt on your vehicle shows this. The exhaust shop that fixed mine charged considerably less than the dealership, and their experience with this problem was evident in how fast they repaired the problem. Chevrolet has a problem, that unfortunately we will have to deal with, but I still would not own anything else. Good Luck
#14
Engine twist breaking exhaust bolts??
I've owned some torque filled engines before, and have never broken exhaust bolts like I've been reading on this, and other sites. I have at least two broken on my 6.0, haven't looked at the drivers side yet. Being I can't afford to be running to a dealer, and wouldn't trust a muffler shop, I'll be doing this myself. My question is, what kind of bolt should I use as replacements? Grade 8? Sure don't want to use OEM!
#15
Just replaced three broken bolts. Noticed them due to a clicking noise in the engine at start up. As soon as the engine warmed up the noise went away. Two of the bolts i removed with vise grips the third broke off in the engine and I had to have it drilled out. Now I have a NEW problem. The engine has a hesitation when idling. No codes showing. Any suggestions as to what may be causing this? Not showing any real loss of power when driving. Thanks.
gruvenparts.com
January 28th, 2016 7:22 AM
gruvenparts.com
May 11th, 2015 2:19 PM
gruvenparts.com
Silverado & Fullsize Pick-ups
lacelles
July 12th, 2007 10:35 AM
