Notices
Old August 11th, 2015, 1:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
check engine light, stabilitrak, traction control, bank 1 & 2 lean
Old July 28th, 2013, 12:02 AM
  #11
those readings were at idle. i did monitor the idle while spraying with little to no change. rps were pretty steady from 590ish to 602ish or something like that.
so 44 is low? i thought that was pretty normal.........are you thinking its my pump?
i'll see what i can do about checking actual pressure with a guage............any other thoughts?
thanks for the recommendations and feedback
jphurst36 is offline
Old July 28th, 2013, 6:16 AM
  #12
The fuel pressure reading should be 55-65psi range, it should be solid and stable...
in2pro is offline
Old July 28th, 2013, 2:16 PM
  #13
i'll head to harbor freight in a little bit to get a fuel pressure guage to confirm. i guess if the pressure is solid at 50 then its the fuel pressure regulator thats bad and not the pump?
Old July 28th, 2013, 4:03 PM
  #14
well, my local HB didn't have a fuel pressure gauge so I had to go to autozone. 48 bucks just to confirm that the scanner reading was correct.
so when i first turn on the truck the pressure is solid at about 58, then drops down to 44 and holds there.
do you think this is a pump issue or a regulator issue? clearly the pump will pressurize to 58, but it isn't maintaining the pressure. what i don't know is if the pressure i'm checking is after the regulator which could be adjusting it from what the pump is providing. checked with autozone and its 368 plus tax for a new pump. i dont want to go that route and waste 400 bucks if its not the pump.
hopefully i'm getting closer to finding the issue. any help would be appreciated.
thanks
Old July 28th, 2013, 4:48 PM
  #15
sounds like it could be a check valve which I believe is in the pump assembly...
But I agree you don't want to replace the pump needlessly...
in2pro is offline
Old July 28th, 2013, 4:55 PM
  #16
so if the check valve is part of the pump assembly then it sounds like i'd have to replace the pump anyways right?
someone else mentioned maybe getting my computer reflashed? any thoughts on that before I go buying a new pump tomorrow?
Old July 29th, 2013, 8:04 PM
  #17
So hey everyone, thanks for the help. I just bought a new fuel pump and installed it. fuel pressure is steady at 58. i cleared the codes, drove the truck for about a half hour and no check engine light. i'm hoping all is well. scanner did not show any pending codes.
however the entire time i was driving the service stabilitrack and traction control lights kept coming on and this time the lights actually stayed on for a couple minutes at a time, not just flashing up and going away. i borrowed a different scanner that did abs and now I'm getting code C0561. It said it was a generic code so I don't know exactly what it means. I'm going to check the forum for that code and see what I can learn, but any help would be greatly appreciated. Gonna get the truck smogged tomorrow and hopefully get my sticker before it expires on the first.
Old July 30th, 2013, 7:45 AM
  #18
Excellent, hopefully it will resolve those issues...might want to try clearing all the codes and see what shows back up...
in2pro is offline
Old July 30th, 2013, 8:50 AM
  #19
Well looks like I was premature in saying that all was good. Looks like I just wasted a bunch of money. On my way to work this morning, my check engine light came on again. I haven't had it scanned yet, but I can only assume that its the same issue. If I scan again and my pressure is low that means I totally wasted my money on the pump and that wasn't the issue. I'm guessing fuel pressure regulator, which also means new intake manifold gasket since I have to remove the intake manifold to get to the sensor???? Help, I'm at my wits end with this truck, what else could it be?
Old July 30th, 2013, 10:45 AM
  #20
I wouldn't be too bummed about it, you could have gone the other way and it could have ended up being the fuel pump anyway... at least now you know that its not the pump, check valve or fuel filter....
And consider what you have saved by doing it yourself taking it to the dealer and they could have troubleshot it the exact same way...
in2pro is offline
Quick Reply: check engine light, stabilitrak, traction control, bank 1 & 2 lean
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
