Ck1500 engine problems need help
ok i have a '90 C1500 automatic and the engine was (shot) so i got found a '92 ck1500 with a standard and did an engine swap. i assumed the engines were the same but maybe i was wrong. ever since i dropped it in its been running rough. at idle it idles down low then it sounds like it revs up some then does it again that only happens in park not in gear or neutral. when driving it runs fine except at a certain rpm it sounds like its missing. i cant figure out the reason. any help or suggestions will be appreciated.
the distributor was reused from the original engine but not the carb. tried swapping the distributor and carb with no change. timing is correct (i think).
more info: the problem with missing only happens when it warms up
Ride of the Month
May 2009
Ride of the Month
May 2009
I had a similar problem that was caused by a faulty connector on the temp sensor located at the manifold gooseneck. Mine would cause the SES light to come on.
yeah i smashed the exhaust temp sensor when stabbing the engine in and the ses light is on but i wanted another opinion before paying for a new one. ill replace it and see if it helps.
chilliwapo
Silverado & Fullsize Pick-ups
December 29th, 2009 9:09 PM
KMaguire
October 11th, 2007 5:14 PM
