DTC codes.. mass confusion
im gettin a list of 4 codesfrom my programmer.. c0035, c0040,c0055 and b1025... i think theC ones are my speed sensors but i dunno why those would go out but im getting 2 different answers for the b1025... the first plaCe i looked said it was an audio output 1.. that would explain why my speaker in my drivers side door aint workin.. the other explination ive heard for it is driver deployment short to voltage and i guesss that would explain my service air bag light coming on... im confused... help..
RE: DTC codes.. mass confusion
what are you driving?
chevy silverado 2006 v6 (go cart)..
[align=left]
• DTCC0035 Left Front Wheel Speed Sensor Circuit[/align][align=left] • DTCC0040 Right Front Wheel Speed Sensor Circuit[/align][align=left] • DTCC0055 Rear Wheel Speed Sensor (Both Wheels) Circuit[/align] • DTCB1025 Audio Output1 (Left Front) Circuit The wheel speed sensor codes sound like it may be related to the electronic brake control module. The code for the lf audio circuit could be a broken, grounded, or shorted to B+ speaker lead. pull the radio and test the leads for a short using a Multimeter |
what would i do about my brake control module?? Dealer problem?.. or is it somethin i can reset?
Well the fact that all speed sensors go ut at the same time leads me to believe that the problem is something other than the speed sensors. And the rear speed sensordoes not accually exist in these trucks. ThePCM send a VSS signal to the EBCM, and the EBCM converts that signal into rear wheel speed. If you still have warranty on the truck I would take it in and the dealer can fix both problems
