Engine Swap 1985 Chevy
Hello,
I have a 1985 chevy silverado c10 with a 350 upon further inspection after i bought it had some holes in the cylinder walls so i removed the block i was given a 1998 350 off a suburban thats EFI.I removed the wiring harness and the transmission that it came with aswell as the distributor and intake manifold, i ordered the correct bolt on manifold for vortec heads from summit plus i still have the carb from the old truck.I was also told my old HEI distributor would work on this new set up.The truck still has the old tranny asuming it bolts right up what else am i over looking? Thanks |
Fuel pump and water pump?
Allan |
thats right i will need an electronic fuel pump the old one was mechanical but. what about the water pump..?
Direction of rotation.
Allan |
