Extra Battery
Hello there!
I have an 07 Silverado that has an extra battery platform on the front driver side. The original battery is on the passenger side fire wall. What I would like to do is run an extra battery with an inverter for camping. Any help with this would be greatly appreciated. thanks Deek |
strip all the parts you need off a donar vehicle that came from factory with dual batteries. other wise you will have to make cables and run them across the engine compartment. make sure you use the proper solenoids that isolate the primary battery from being discharged when the engine is off.
