floating gas gauge
What would cause your gas gauge to float when your truck is in park and your idling. PLEASE HELP!!!!!!!!!!!!!!!!
RE: floating gas gauge
I have a issue that is similar. When my 2001 5.3 Z71 is totally full on gas it will drop totally empty and the gas light comes on. Then if I put into drive or hit a bump it comes back to full. It only happens when it is full. Strange,
replace the level sensor in the fuel tank
drop tank, remove and replace float, pump, and sensor.
Might be easier and cheaper to get a whole sending unit. should be one piece. find part number and comparable models used. might get ebay or junk yard
hey fellas, i think i just need to get a new fuel pump and problem solved right.
[/align] |
its in the tank
dont quite follow you [/align] |
fuel pump is the "sender" unit. it is located inside the fuel tank . that is where the float that measures your fuel level is attached.
i get that [/align] |
