Front Axle Torque Specs 2004 Crew Cab 4x4
Hello all,
Looking to see if anyone has the Front Axle Nut Torque Specs for a 04 Silverado Crew Cab 4x4. I have to replace the drivers side hub and all I can find is either 112 ftlbs or 155 ftlbs. I was told that if I overtorque I can damage the bearings which is why I am replacing the hub to begin with. Any help is appreciated. |
Looking to see if anyone has the Front Axle Nut/hubTorque Specs for a 04 SilveradoCrewCab 4x4. I have to replace the drivers side hub and al
alldata say 177 ft lb
I used to be the guy that watched the torques that were MVSS thoughout the plant.
I can't recall all of them, but this was next to the highest torques in the plant. Do not reuse the old nuts. Car/ or truck. A Chilton Book that can be found in the library would have that information for you. Good luck, Lee |
