grinding and knocking, silverado
I have a 2000 Z71 1500. When I am driving straight down the road I can hear an awful grinding (I can also feel it at my feet). When I turn SLIGHTLY to the right, it goes away. When I turn the wheel halfway to the right, like if I am taking a long corner, it knocks. I can also feel that at my feet. Also, when I was doing the long turn, I swear I heard my tire chirp.
Is this the front axle cv joint going bad? Its the only thing I can think of. I thought maybe it was a bearing, but with the knock in the long turn, I thought maybe the axle. Any help would be appreciated, I am checking local prices and when I am sure what it is, I will be replacing it. Thanks. |
could be a wheel bearing...maybe cv...just have to starting checking out the front end
Jack up truck and play with wheels and find clunk or grind
UPDATE: I thought I had it figured out, changed out the cv axle. It helped the problem a little but I still have some grinding and a knock. When the truck is jacked up, the tire feels a bit loose, has some play in it.
I'm thinking of changing the bearing next, I don't know what else would be grinding. Also, cant tell if its grinding when I spin the wheel, just when I am on the road going over 20 or so. |
probably the bearing, grab the top and bottom of the tire if it rocks then the bearings loose
Hey Everyone, can some one please give me a ball park figure as to how much it will cost to convert my 1990 v8 chevy silverado to a v6?
1000000
Originally Posted by Nicoward
(Post 214038)
For camotruck55 yes it definitely sounds like a wheel bearing, but I would definitely check those ball joints. Wiggle the tire up and down and side to side and look at ball joints, tie rod ends
Cleveland and Fish, I ended up changing out the wheel bearing over the weekend. That fixed the problem, the bearings were all beat up and bone dry. The ball joints and tie rods seemed to be ok, so I think this is the end of the problem. Thanks for all your help.
