Help lifting my HD2500 longbed
2 Attachment(s)
hi. i just got a 2500 with an 8 ft bed. i was thinking about putting a 6" lift with some nito 35s. what do you guys think? if you disagree, which lift should i put on it, and which sized tires? the rims are 16's right now i believe.
6" on 35s will look good. Dependin in the budget you could go with all sorts of different lifts
Originally Posted by country_09
(Post 264898)
Well what wheels/tires do you want to run then decide what size lift you want
(Post 265109)
That's the width, how big a tire? 33,35? A 33 can be run with just a levelin kit and a tad bit of trimmin
(Post 265198)
heres what i would like. nitto grapplers 295/70/18r which converts to 34.3/11.6/18r OR BFG's 35X12.5R18LT the wheels i want are moto metal 18x9 with a 8x6.5 pattern with a -12 offset. how is that affecting things? |
with a 6" that setup will be fine
