Notices
Sponsored by: DashLynx
HELP! No Power Steering and Brakes
Old February 22nd, 2010, 9:45 PM
ssimpson30's Avatar
Talking HELP! No Power Steering and Brakes
Hi, i have a 2004 2500dh 6.6l the power steering and brakes do not work at all. i have replaced the power steering pump and the hydroboost. Still no improvements. System has been bled to spec. I removed the pressure line going into the hydroboost from the PS pump and started the truck. Fluid barley pumped out and it was filthy. must be pulling fluid from the gear box. Could the gear box be faulty? Is the pump working properly? Could there be a blockage somewhere? Any Ideas?
Old February 22nd, 2010, 10:22 PM
maxxman04's Avatar
sounds like a clogged line or bad pump.
Old February 22nd, 2010, 11:28 PM
nauticstar87's Avatar
Werd... New doesn't mean good.
Old February 22nd, 2010, 11:59 PM
wobblypop's Avatar
check the lines if any of them have colapsed inside,does the pump make a whining sound if it does the pump is cavatating pumping air/oil due to a restriction, you could also have someone start it while you watch the lines and look for a line that jolts when it first start a kinda follow it from there
Old February 25th, 2010, 1:40 AM
ssimpson30's Avatar
Thanks alot guys for your input. as soon as the weather gets a little better i will check out those things and get bak to ya..
Blaine B.
Express & G-Series Vans
12
April 2nd, 2015 12:00 PM
buddho
February 5th, 2015 9:52 PM
dcommons
February 27th, 2011 9:22 PM
92chevysilvy
November 30th, 2010 1:57 PM
HeatDet
Astro
15
June 9th, 2010 9:18 PM
Quick Reply: HELP! No Power Steering and Brakes
