High Idle CEL Flashing
Hi everyone Im James Im new to this Awesome fourm. I have a 1996 K1500 5.7L & its been a great truck its got 211,500kms, but lately It is idling very high it likes to accelerate up to 40km/hr without touching the pedal, the cel flashes only when i start it up and after 30secs of driving it goes out. Ive replaced the Tps, Iac, wires, Plugs, Cap & Rotor, Pcv, TB Gasket. Im taking it to a shop on wedesday but im hoping i figure it out. I just had a 360 spinal fusion or i would fix it myself any advise is greatful.
Thanks
James H.
Thanks
James H.
These are possible causes. From another site.
- Dirty throttle body
- Electric throttle control actuator misadjusted or damaged
- Faulty Electric throttle control actuator
- Intake air leak
- Poor electrical connection to the Intake Air Control (IAC) valve
- Intake air leak
Former Sponsor
There are many reasons for po507 code coming again and again even after IAC has been changed. Have you checked the IAC motor connector? If it is ok then check for any open or ground IAC circuit.
Where is the Electric throttle control actuator located ?. Ive cleaned the TB right up & sprayed TB cleaner all over the engine with it running and got no change.
Thanks for the replies
in2pro
December 25th, 2020 11:34 PM
otis_xing
Silverado & Fullsize Pick-ups
April 13th, 2013 2:31 PM
militarydave
Express & G-Series Vans
January 29th, 2012 5:44 AM
