How to disable fuel pump 07 NBS
I need to know if it is possible to disable the fuel pump in a 2007 NBS with a 5.3 AFM. I have already pulled the fuel pump fuse and relay, truck still runs and has correct fuel pressure.
Only way I know of it to unplug the fuel pump itself if the others don't work
Originally Posted by jwruss
(Post 245480)
Yes I pulled the right fuses and relay. Had a pressure guage on the line at the time. Found out thru Alldata that the oil pressure switch also has to be unpluged.
