Idling issues
1999 Chevrolet Silverado extended cab Z71 with a 5.3 liter.
<O:p Problem-It starts fine when it is cold, and runs fine. As soon as it is warmed up, it hard starts. It takes about 7-10 turns to start, unless I hit the gas then it sputters and starts after about 4-5 cranks. Again, once warmed up it will start to stall at stops and occasionally it does stall.<O:p</O:p <O:p 2 months ago the fuel pump went out on it, and I thought that it was it. So I had the pump, filter and relay changed, and it still does it. Any input to any ideas that you guys have would be so appreciated. Thank you for looking! |
check the fuel pressure regulator vacuum hose, if it smells like gas then it is bad, i have seen them do this before
Thank you so much! That was it, runs like new again:D
