intermittent abs brake issue
I am having a problem with my 02 chevy 2500 hd abs brakes. when I go to brake, the brake pedal pulsates. It does not matter if I am on a dirt road or pavement, doesn't matter what the weather is (could be sunny!) and I don't have to be going fast like you normally would to feel the abs brakes to come on when you slam on them. And it doesn't happen every single time. There is no abs light on at all. Had the mechanic look at it and drive it...can't find anything wrong with it.
RE: intermittent abs brake issue
I am having the same issue with my 2001 Chevorlet Silverado 1500 extended cab 4x4. 5.3 V8 Vortec.
I've had the low speed sensor replaced with a new one and had new tires put on. This did not fix the problem. |
im having same problem also, I have the same truck as you CdnFD24, 2001 chevy silverado 1500 ext cab 4x4 5.3 v8 vortec, it does it maybe 5 - 6 % of braking time. on dry roads
Maybe a vacume problem going to the brake booster?
When you feel the brake pedal pulse ... do you hear the ABS actuator engage ?
I have the same issue with my '01 Silverado 5.3liter 4x4. The ABS motor cycles 80% of stops but no light is on in the dash.
ORIGINAL: bluechevy I have the same issue with my '01 Silverado 5.3liter 4x4. The ABS motor cycles 80% of stops but no light is on in the dash. Having the ABS come on is not that uncommon. It can be caused by wrong tire inflation , wrong size tires , wheel hop while braking , sloppy wheel bearings , dirty or broken teeth on the reference ring , loose sensor pickup , etc. |
Go to www.car.com, there you will find a re-call for that problem. The dealers will make the repairs. I think at no cost to you. This re-call was back in 2005, campaign # 05v379000, You can call chevrolet at 1-800-630-2434 for more info.
I hope this helps all of you |
Same old abs pulsing issue.
On my 01 Suburban my brake petal pulses sometimes when braking making as loud noise and wont stop unless I pump the brake once or twice. The comments here are old. So what is the fix? I have spent tons of $ trying to get this fixed.
Help ! |
