Lean to the left.
I cant figure why my truck is leaning to the left. when you look at it from behind the passenger side is slightly higher than the driver...
RE: Lean to the left.
My 04 had the same problem, the front had a compressed bushing that needed to be replaced, it was a TSB that was replaced out of warranty for free. Dont let them tell you that its because your gas tank is full, I had them print out the procedure for fixing the compressed bushing and it says to weigh the truck down to simulate a full tank. So a full fuel tank most likely is not the problem.
