lift kit
lift kit
Hey boys looking to put a lift kit on my 94 1/2 ton. I was wondering, what look best? I don't want anything big just a 2" or 4". I'm very interested in a suspension lift. how are these? do they make the ride any smoother? just fill me up with info I don't know a lot about lifts
thanks
thanks
Hi Chev350!
In my humble opinion, suspension lift outperforms body lifts and, to me, look better. Regardless of what lift you install, your ride will not be as smooth as stock suspension.
Am I right to assume that you have a 1994 Chevy K1500? If so, I know of two lifts that might do well for you:
http://www.summitracing.com/parts/sj...et/model/k1500
- This is a 2 inch lift kit designed to lift the rear 2 inches and lift/level the front with 4 inches. It's a little on the cheaper side.
http://www.summitracing.com/parts/ex...et/model/k1500
- This is a 4 inch lift also designed to lift the rear 4 inches and lift/ level the front with 6 inches. It's a bit more pricey, but Pro-comp lifts are virtually bulletproof.
Hope this helps!!!
Hope this helps!!!
mrpete
Silverado & Fullsize Pick-ups
February 24th, 2014 7:50 PM
hidextra.com
September 7th, 2010 2:38 PM
socks
September 24th, 2009 1:07 AM
boosteda4tq
May 30th, 2008 9:28 AM
