looking for a glasspack
im looking for a glasspack thats not to loud. i want more of a low " wet " roar. any suggestions.?
5.7 vortec stock exhaust. im cutting it off behind the muffler, leaving the stock headers and cats. and runing duals out the back with the new glasspacks im looking for. correct me if im wrong, but thats not really enough exhaust work to change hp or mpg right? |
You might look at flowmasters. Anytime you less restrict the exhaust you will realize more HP. As far as emissions I dunno. If you have a state requirement for emissions, you might ask someone else as I don't have emissions here.
thanks. ill check them out
Flowmasters restrict the exhaust out of any other aftermarket muffler I've ever seen...from what I've read only do duals with a x-pipe added in and don't go over 2.25"-2.5" pipin on it.
im liking thrush the most right now
Thrush is the same as flowmaster..just a knock off. If you want a low deep rumble check out magnaflow
i will have a crossover most likely
Originally Posted by country_09
(Post 195806)
Check out Spin Tech mufflers, they are right at the top on flow and great sound. Determine which mufflers you like for performance then search YouTube for sound clips. |
Originally Posted by slw210
(Post 195875)
Thrush is part of Walker, which also has Dynomax. Thrush and Flowmaster are restrictive, but Walker and Dynomax have the least restrictive exaust according to flow comparison and dyno comparison. Just Google "Least restrictive muffler" and "performance muffler" etc. you will come up with some good info. Magnalows are ok and sound great, but performance wise they are middle of the pack.
I disagree about the flowmasters being restricted.
Inside them are designs that create a negative pressure in turn pulling exhaust Out of the pistons which will ultimatelly net you more horse power. Glasspacks sound like crap to me. They are just loud and raspy and arrogant. My flowmasters are perfect. If you want something that is just loud, go with true dual flowmaster 10 series. |
