Low Beams not working
Hello all,
So I was replacing one burnt out low beam and when I turn on the truck both low beam lights not working now. DRLs and highs work, fogs too, everything except the lows!!! Checked fuses, relays and replaced dimmer switch on dash but no luck. What next the multi lever switch on steering column??? 2005 silverado |
I would check for voltage and ground to each bulb.
ok, once it stops raining here in Houston i will do that. can't fit the truck in the garage.
