Moaning Sound Only on Left Turns
I have a 2004 Silverado 1500 crew cab and almost every time I make a left turn there is a loud moaning/rubbing sound and the steering wheel slightly vibrates. I had my wife turn the wheel over and over to the left while I listened with the hood open and I am almost certain I have pinpointed the source of the problem, but I don't know enough about trucks to be sure.
There are 2 hoses/lines below the battery that shake whenever I hear the noise. Are these power steering lines? What are these lines for? Does anyone have any ideas? I am not low on PS fluid and it never ever makes the sound on right turns, only left. I also lifted the truck up and felt for play in the front tires, but they were both solid. It's not the steering knock as I already tried lubing the intermediate shaft a while back. It's more of a moan or groan than a knock. I feel like it has to be related to the hoses shaking whenever I hear the noise... |
Did you ever find a solution to your steering problem? Mine is doing the exact same thing. Thanks for any help.
Sure its not the front end, sounds like a hub to me and if you haven't figured it out post a video and I am sure someone can figure it out.
wheel bearing
Sounds like a bad wheel bearing to me.
Thanks for the help. I'll check the hub/bearing
I have the same noise. It seems to be coming from the power steering pump. Sounds like Chewbacca during left turns only.
Hey guys, it's been a long time but I thought I stumbled upon this thread doing a google search for a new issue i'm having with my truck and thought I would share that I did find the steering noise issue. I was getting my oil changed and thought what the hell, i'll have them replace my power steering fluid while they are at it...and sure as ****, I drove away in silence. No more noise ever since!
Hopefully this helps someone down the road. |
Thanks for the feedback. Doesn't sound like a bad idea once I get my truck running again. Ol' girl had been beginning to whine.
I Don't think so...
Originally Posted by tyleralt56
(Post 243039)
