more hp
what would be a quick or easy way to get a few more horsepower out of my truck? I got a 98 silverado ext. cab 5.7L vortec v8. I got it lifted around new years and now I want to see if I can get some more power out of it. It also has cold air intake and flowmaster exhaust. I thought about getting new cams but wasn't sure if there was anything else I could do. I'm kinda on a tight budget right now.
Thanks, Austin |
If you put bigger tires on when you lifted it then it's time for some new gears.
4.56 would work good on your truck :D:D or 4.88
ok, yeah that's a good idea. I got 35's put on so I'll probably go ahead and do that. Thanks
You would need to invest a lot of money to gain the HP required to get the same result of a gear change, it can be expensive if you can't do the gears yuorself. I would go with the 4.56 if you use it as a DD.
Also a set of headers and a programer will gain a few hp.....maybe some roller rocker arms...they are usually somewhat affordable and easy to install
I swear by duct tape... Put that anywhere on your truck, you will gain horsepower...
lmao. nice one. if you have the money. do what nautic is doin and get a tune from blackbear.
lol, I like your style.
I have looked into getting a programmer, but it's harder to find programmers I like for a 98. It seems like a number of programmers don't support silverados earlier than 99 |
Originally Posted by nauticstar87
(Post 132237)
