More power from my 05 5.3
I'm looking for information on how to get about 400 hp out of my daily driver 05 Silverado ,probably lookin to do cam swap ,change intake ,get programmer ,I have already put cold air intake on it
400hp to the wheels? Won't happen with just that. Prolly not even crank power. Best best for more power, drop a 6.0 in there, put longtube headers, intake, cam, and do a custom tune. Not a handheld programmer please. That'll get you close
boost!
Stock motor with boost equals low reliability.
So what is the reason you want 400 HP engine? Work or play? Did you plan to go though or up grade the trans, differential, brakes and is it 4WD with big tires?
To do a lot of work like pulling a trailer the whole powertrain and brakes work harder. For play a big engine will ware out or beak everything else sooner. If want this for work: research upgrading to a vehicle that better fits your needs. You may find newer stronger more reliable vehicle will be cheaper in the long run. For play on a budget: you may want to also look at tire size and gear ratio depending on what you have now. |
Originally Posted by 2000z71
(Post 312047)
the entire aftermarket industry is based on building on stock engines. here is one kit from a 5 second search. you be at 350hp at the wheels. no bottom end build required. the trans will be done long before the engine I bet. http://www.edelbrock.com/automotive/...ruck-suv.shtml |
Originally Posted by tech2
(Post 312077)
hog............wash. this engine can handle 9psi of boost. Maybe you built yours wrong.
the headgaskets on my 10psi w body are holding just fine after 11years. a k truck will run the same.
