no power to the fuel pump when i turn the key on
I have a 91 chevy truck k1500.
It ran fine when i took it out of the truck. I put the motor into another truck and now I have the problem. I changed the send unit and pump initially. Now I don't have any power going to my fuel pump when I turn the key on. I ran a hot wire to the pump and it runs. If I put gas in the throttle body it fires up until it runs out of gas. I changed the ecm the fuel pump relay. I ran another ground to the pump just in case it was bad.My fuels are good. Can anyone off some other places to check. I understand the process but what I can't seem to find is why it won't turn on as soon as I turn the key on. https://chevroletforum.com/forum/ima...ttons/edit.gif |
Put the original ecm in and tell us what it does.
