Oil/fuel gauges help!!!
Hi everyone, I got a 1992 chevy 2500 with the 5.7 my oil pressure gauge and fuel gauge dont work. Both just stay maxed out with the truck on or off I can put the needle down with truck off and shoots right back to max as I turn it on. Would these be related to each other like there running on the same wire by any chance? It's not the cluster I tried a different on and does the same exact thing. Seems to be grounding out somewhere. Thanks
Pull the fuse, then figure were the short is.Probably the sending unit.
Last edited by kevinkpk; May 17th, 2019 at 8:18 PM. Reason: Probably the sending unit
