Power steering hose help
Blew a hose tonight pulling out of my driveway, pulled back in and looked at it best I could in the night. Looks like it came off of the metal tubes that is sticking up, has this happened to anyone and is it easy to fix? I looked on youtube for some help but didn't see anything. I'll check back tomorrow sometime on this, thanks matt
looks like it was my return hose, I clamped it back on filled the pump with new fluid but now it won't work at all? Do I need to bleed my system to get the fluid in the lines?
Originally Posted by gray gables
(Post 262210)
If this does not work,it might be it might be the pump itself. Was it whining before the hose blew? Does the oil smell burnt? I would buy new return line just incase the one you have might be collapsed ,they are fairly cheap around 20-25 bucks and easy to install. |
