Notices
rear hub bearing replacement
Old April 11th, 2013, 8:47 PM
bilwilli's Avatar
Default rear hub bearing replacement
does the rear hub bearings on 02 silverado 2500hd need to be packed with grease or does the rear end lubricant supply the lubricant.took the hubs off and they appear not to have grease on them...
Old April 11th, 2013, 9:23 PM
the bearing is lubricated by the diff flluid. When you put the hub/bearing back to on; make sure you fill the bearing cavity full of diff fluid then put it in place and tighten it up. If you put it on dry, by the time the diff fluid gets to the bearings...they will be toast.
Old April 11th, 2013, 9:50 PM
tymr287's Avatar
After I replace them and refill the diff, I jack up the opposite side to let the gear oil run down to the bearing.
Old April 12th, 2013, 7:54 AM
bilwilli's Avatar
Thanks very much, that's what I thought,
Old April 13th, 2013, 9:21 AM
cleveland63b's Avatar
i usually grease pack the bearings on reassembly to help with the dry/hot start...either way put oil in the hub as mentioned
doug5gUPLANDER
Uplander
September 30th, 2011 4:23 PM
jrsavoie
April 15th, 2010 10:58 AM
whitesatin
February 16th, 2008 11:10 PM
settlesean
April 9th, 2007 6:59 PM
waycon
July 2nd, 2006 2:31 PM
Quick Reply: rear hub bearing replacement
