Notices
rough idle and stall after installing cold air intake
Old August 28th, 2011, 12:25 AM
Default rough idle and stall after installing cold air intake
Hi everyone I am really bummed right now! I've had my 2004 silverado z71 since new and just recently have been bitten by the mod bug! So around 2 weeks ago I installed a Flowmaster super 40 and I love it! Then today I picked up a K&N cold air intake and put that on. I was so ready to start it up and when I did it idled rough and stalled out on a test drive, twice! A friend of mine said his truck fired up and kicked butt right outta the gate when he installed his cai. I could use any imput if you have any.....HELP!
silver389 is offline
Old August 28th, 2011, 1:26 AM
Mille Racer 69's Avatar
It will be running more lean, but shouldn't stall.
Hoe many rpm's is it idling at?
Is the Cai fitting firmly connected?
No gap anywhere?
you didn't umplug any air sensors did you?
Mille Racer 69 is offline
Old August 28th, 2011, 8:19 PM
First make sure the MAF is connected and also installed correctly and if so make sure you did not oil filter so much as it clogs the MAF. check for any air leaks especially aound tube you connected to engine. The plastic K&N tubes leak right at that point,
ToooTall1 is offline
Old August 28th, 2011, 10:26 PM
20redfrogs's Avatar
+1 on the MAF... Make sure you have it reconnected, and that it is not flipped backwards...
20redfrogs is offline
Old August 30th, 2011, 8:57 PM
Hey thanks you guys for the replies! Well I removed the entire intake and re-installed it. Started the truck and voila! I'm guessing as you guys said I had an air leak and or the maf was not plugged in correctly. As far as the intake, it definately improved the throttle response but not anything to crazy. Now on to headers! Any suggestions?
Old August 30th, 2011, 9:45 PM
Harris, edlebrock,
Tbh, a cheap pair at autozone or Kragen will likely be just as good.
Go longtube if you can, as long as you don't have any legal smog issues.
Some headers have a problem with a little pinhole leak, but if you
Put exhaust wrap around the headers, you won't hear the faint ts-ts-ts-ts-
Sound if there is a little hole. Or if you for some reason are against wrap,
You could easily find the hole and 1 little spotted weld will fix the problem.
But outing on some exhaust wrap will actually help your cold air intake work
Better. It will also net you power gain in other ways too.
While you're at it, pick up some granatelli spark plug wires to get you
About 15 more HP.
Most plug cables for cars are several thousand ohms. With all that resistance. The current that
Gives the plug its spark has to work harder to get to the end of the wire.
With granatelli, their wires have only 2 ohms of resistance. So essentially all of the power
That goes into the wire comes out the other end. The result is better response,
More power, better fuel efficiency and a much smoother running engine.
Mille Racer 69
17
November 7th, 2010 4:19 PM
SilveradoShane413
February 3rd, 2010 9:19 PM
BRozier11
15
May 30th, 2009 11:56 AM
Graphicman
January 29th, 2009 6:30 AM
houszton
Private 'Wanted' Classifieds
June 30th, 2006 5:10 AM
Quick Reply: rough idle and stall after installing cold air intake
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
