Spray on bedliner for 2005 silverado 1500 HD
Hey Guys! I'm new here and I just turned 16 and got a used 2005 Silverado for my bday. The bed is a little messed up so I'm gunna by a spray in bedliner. My bed is 6'7" and my question is, how much would this cost? Thanks in advance :)
anyone?
Hello
depends on what product you go with..i see alot of cheap knock off spray on bedliners you can get the stuff in aerosol cans, roll it on, or buy a special paint gun my advice would be go to your body shop and ask a price Most shops i know do that or the will send u to a place that will The rhino lining getting it proffesional will cost about $300 give or take Or you can get spray cans and do it yourself for about $100 and thats with putting a few good coats on |
Mine cost me about 400$ out the door four years ago. One of the best investments I ever made. Don't worry about current damage to your bed, they have to scuff the bed anyway to install the liner. Get Rhinoliner done by a shop, it's almost bulletproof.
1 Attachment(s)
My bedliner costed $320. The Z71 inlay costed $40. Its Super-Liner and is a little softer than rhino lining, so things don't slide around as bad.
Attachment 15294 |
$500 for Line-X over the rails, 08 Silverado crew cab.
bedliner spray
The cost of qwikliner is around $300.It is better than others.
Superliner and Qwikliner use a low pressure/room temp application method which is not the best method. The best method is high pressure/heat. With high pressure and heat, you get superior adhesion and much more uniform looking and a less "chunky" looking bedliner. LINE-X only uses a high pressure/heat application system. Rhino has both low pressure and high pressure. However, LINE-X is 31% stronger than the Rhino high pressure bedliners (Tuff Grip and Hardline).
spray on bedliner
High pressure system there are more options XTREME liners are more superior than line-x and rhino.In Low pressure system qwikliner is the best option.
my buddy had his long bed dodge 3500 done for about 325 (not sure what brand) i know it was hi pressure but more then that i dont know, but i will be going to get mine done soon
what ever you do make sure they guarantee it not to end up like what i need to get redone in mine....my buddies dad had this done before he passed so we dont know who did it, but if i did i wouldnt recomend them: http://i196.photobucket.com/albums/a...uck/truck6.jpg |
