starter clicks once
sounds like worn starter brushes. have someone hold the key to start and tap the starter sharply with the butt end of a long pry bar or tap with a hammer. stay clear of moving parts!!
should be on the right side under the exhaust manifold. might be able to access it through the right wheel well if you pull the rubber shield up. If not access either top right side of engine compartment or under the truck on the right side.
tracerbullet
December 6th, 2012 2:49 PM
02rubio
August 22nd, 2007 7:30 PM
