starter grinding
Hello everybody. new to the site! any way, i am having an issue with my starter grinding against my flexplate! vehicle is a 72 c10, motor is out of a 95 c1500. i dropped the motor in about a year and a half ago and everything was fine. one morning we get in to start it and it makes an aweful sound. after pinpointing the issue we have been messing with it since.
i have replaced the starter 2 times and just put in a new flexplate about 8 months ago. all has been fine until a couple of weeks ago the problem has come back. now no matter what i change it still grinds. i tried shims but no go. i did notice that the bendix is sticking sometimes and wont dissengage. my plan is to redo it all over again, but was looking for some advice. |
you might need a few more shims, if the bendix is sticking. or try using shims on one side of the stater
Make sure all your batt cables are clean and tight.
does any1 know if these flexplates are prone to warping or any other failure? the engine runs fine once i get it cranked? could there be other problems associated with why i am constantly messing with this one area?
Originally Posted by fattest1here
(Post 193882)
yeah i am not droppin the trans again to do this. i do not have the cover on mine. also i wish i could even get the damn thing to start. i know for a fact that some of the teeth are messed up. i might just have to tow it to my place and get it in the garage so i can be on level ground, and mess with it then.
(Post 194025)
