Notices
symptoms
Old April 7th, 2009, 11:44 PM
  #11
98white5.0's Avatar
Now for Suzuki. I would go ahead and disconnect the battery for a few to reset everything. It might help. Have you checked for trouble codes?
Old April 7th, 2009, 11:56 PM
  #12
suzuki-guy's Avatar
yeah i wish mine seemed like a sprots car but i have to fix this problem firtst!!! No codes thats the thing thats getting me!!!
Old April 8th, 2009, 10:58 AM
  #13
therewolf's Avatar
From a practical point of view, if it's OEM, it's ready for it's retirement party. If it's not ******* you now, it soon will.
Old April 8th, 2009, 12:46 PM
  #14
98white5.0's Avatar
Huh??
Old April 8th, 2009, 3:54 PM
  #15
suzuki-guy's Avatar
what are you talking aboiut??? ive already rebuilt the bottom and top end of this engine its got a lot of life to go my friend!!
Old April 8th, 2009, 5:43 PM
  #16
Ride of the Month
May 2009
mudmaniac's Avatar
I was having a similar problem when I put on my Edelbrok Performer TBI manifold and it turned out to be the temp sensor next to the manifold gooseneck.
I don't think you have the same problem because mine did throw a code, but it acted exactly as you have described.
Old April 8th, 2009, 5:55 PM
  #17
suzuki-guy's Avatar
Yeah i thought thats what mine was but i replaced it already my temp gauge didnt work when my sensor went bad and it didnt throw a code. did your gauge work when yours went bad?
Old April 9th, 2009, 6:29 PM
  #18
Ride of the Month
May 2009
mudmaniac's Avatar
I'm not sure, I think it was because I generaly watch the gauges.
Old April 9th, 2009, 8:36 PM
  #19
Professional Mechanic
MDTAHOE's Avatar
There are two temp sensors. The single wire one is for the gauge. The 2 wire one is for the computer. It sounds more like a fuel delivery problem then ignition but it had to be sure with out actually seeing the truck. You say the fuel pressure is normal but how fast does the pressure fall off when you turn off the key. If it counts back rapidly something is leaking down. Injector, regulator or the pump. Has anyone ever taken the t-body apart?
Old April 9th, 2009, 8:45 PM
  #20
suzuki-guy's Avatar
new update>>>>> i looked at my truck while it was running i noticed a drip coming from the fitting in the back of the throttle body now obviously this has to be fixed but does it have a oring? does the fitting on the throttle body have a gasket? my lines are not rusty so i will try to replace the gasket and/or oring. also where could i find this oring? is it special because of the gas pressure?
Quick Reply: symptoms
