Notices
Sponsored by: DashLynx
Old July 22nd, 2015, 7:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Trying to program key fob, 1999 Chevy Silverado 1500
Old June 11th, 2018, 6:20 PM
  #21
jfayadjr's Avatar
No I have not figured it out still. I'll probably end up going to the dealer unfortunately.
Old January 19th, 2019, 3:22 PM
  #22
MadMan's Avatar
Default 2000 z 71
I realize this is old but I been having same issue, after reading a lot of info I found a forum that said to pull the high beam selector back and hold it instead of the unlock button, it worked on my 2000 model, everything worked perfect ! All steps completed and the new remote cycled when I held both buttons, but the fob still will not work????
Old January 19th, 2019, 3:27 PM
  #23
jfayadjr's Avatar
I'll have to try that!!! Thank you!!
Old March 15th, 2019, 5:03 PM
  #24
Aaa091600's Avatar
Mine worked as well and cycled through with the key fob. Key fob will not work after either. Did you find a solution?
Old March 15th, 2019, 5:05 PM
  #25
jfayadjr's Avatar
No not yet. Pisses me off!
Old March 15th, 2019, 5:19 PM
  #26
Aaa091600's Avatar
I can’t find anywhere else online that says to do it that way. It’s the ONLY thing that has put it into programming mode though.
Old March 15th, 2019, 5:23 PM
  #27
jfayadjr's Avatar
Mine goes into programming mode using the original method (unlock button) but my remote will not program. It's the correct one for my vin. I just don't want to take it to a dealer and pay out my ***. I was actually thinking of getting an aftermarket car lock system. Saw one online for $12! Everything included!
Old March 15th, 2019, 6:06 PM
  #28
Jeremy Hubbard's Avatar
Default RKE issues
If you cannot enter program mode your issue is with the BCM located under steering column.
if you enter program mode and remotes do not respond your issue is with the receiver located under dash pad above instrument cluster.
Old March 15th, 2019, 9:27 PM
  #29
MadMan's Avatar
Default Key fob
The fobs respond after you cycle them but then they stop?
Old March 15th, 2019, 9:50 PM
  #30
jfayadjr's Avatar
I thought it might be that. Can I get one from a junk yard or do I have to order it new?
Quick Reply: Trying to program key fob, 1999 Chevy Silverado 1500
