Upper control arm
Can I use a normal bolt or do I have to use those bolt came factory?:confused:
No one has any thing? So then I can use bolt at the local hardware store. Because I broke the one on my truck.
If you find one of the correct size and thread make sure it is a grade 8 bolt. Anything less will break again. You can try NAPA stores for proper machined bolts for your vehicle.
