Notices
Sponsored by: DashLynx
Vendor that sells t-case gasket set
Old May 19th, 2009, 10:43 PM
mygreenihc's Avatar
Default Vendor that sells t-case gasket set
I have a 95 K1500 that has an NP241C transfer case. The transfer case works fine with no noise, but it has a small leak. I have searched but cannot find a vendor that sells only a gasket set. Finding a set with bearings is not hard, but I don't need bearings. Does anyone have a suggestion as to who might?
Thanks,
Brad
Old May 19th, 2009, 10:46 PM
suzuki-guy's Avatar
If you can locate where exactly the leak is coming from Autozone sells single gaskets. Is it coming from the output or input shaft?
Old May 19th, 2009, 10:48 PM
mygreenihc's Avatar
It is leaking from the output shaft. It does not look to be a bad job to change it.
Old May 19th, 2009, 10:52 PM
suzuki-guy's Avatar
Autozone sells one check this link out!http://www.autozone.com/autozone/cat...em%40108ff9%5D
Old May 19th, 2009, 10:59 PM
mygreenihc's Avatar
Thank You Zuk-man. It is actually leaking where the output housing connects to the main transfer case. I will replace the rear seal while I have it off though. That leads me in the right direction. I will go by there tomorrow at lunch. Then, soon as my AMSoil Severe Gear oil gets here, I'll be in business.
Thanks,
PS: are you ALWAYS on here?
Old May 19th, 2009, 11:21 PM
suzuki-guy's Avatar
Im always available from 3:30 to 2:00 in the morning(michigan time) When somone post on here it notifys me on my cellphone!
Old May 20th, 2009, 10:35 AM
therewolf's Avatar
I never met a Fel-Pro Catalogue I didn't like, but I've met quite a few lazy counter parts guys who didn't want to be bothered to look it up IN the cat...
Worst come to worst, there's a lot of good RTV sealers which you can use as a gasket substitute.
DCSCO
November 26th, 2011 8:20 PM
dh1
June 16th, 2010 2:16 PM
shockguys
June 10th, 2009 7:33 PM
Quick Reply: Vendor that sells t-case gasket set
